switching to 89' MAF ecm
Old Jan 24, 2002 | 06:22 PM
SMURFN' Z28's Avatar
Car: 1994 Jeep Wrangler
ok i have an 85' 305 TPI Z28. i also have the ecm from my old car... my 89' formula 350. i have been thinking about installing the computer from the 89' as the computer from the 85' sucks. i will need to burn a new chip because the 89' ecm is from a 350, if i was going to use a stock prom set, what year 305 would yeild the best results? by the time i do this i will have done some slight mods.
Old Jan 24, 2002 | 06:27 PM
also... will i feel any performance gains from the ecm switch?
Old Jan 25, 2002 | 08:42 AM
GregWestphal's Avatar
Car: '87 Camaro IROC-Z
Engine: 385 HSR
Axle/Gears: 3.42 posi
Re: switching to 89' MAF ecm
For this, you'll need to modify the wiring harness some. Go here:
http://www.eecis.udel.edu/~davis/z28/ecm_swap/
for the best documentation on this swap. You can look in the GMECM bin library (see posts from yesterday) for the APYM if you have an automatic. Mike has the '89 305 M5 bin on his website if you need that one. For best results, get the ARAP bin, change the necessary parameters for your 305 (injector constant, idle speed, lower the timing table some, etc.) and have fun. AFA your other question, you'll pick up performance by burning your own chip more so than going with the '89 ECM.
Old Jan 25, 2002 | 10:08 AM
Greg '85 T/A's Avatar
Car: 1985 Trans Am/WS6
Engine: 5.0 TPI
. . . the computer from the 85' sucks.
Geez boyz and girlz, can't we just say that later ecms offer more flexibility - you're hurting my feelings
89GTAOz
May 16, 2020 09:31 AM
mddaniel
Sep 8, 2015 05:16 PM
NBrehm
Aug 25, 2015 11:49 PM
trevor1010
Aug 24, 2015 11:29 AM
Bert87
Aug 23, 2015 03:50 PM
