EBL P4 with stand alone trans controller Q
I have the ebl p4 running everything. I went from the 700r4 to a 4l60e with a stand alone controller. Would you flip option word 2 bit 7 TCC off to indicate a manual trans? Or?
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: EBL P4 with stand alone trans controller Q
Just curious, why you would change yours to a manual in the tune vs leaving the stall saver logic alone ?
How would stall saver logic be related/ still be valid/usefull? And doesn't stall saver logic run irregardless if manual trans checked?
Engine: Lb9
Transmission: M20
I would think it would be a good idea do leave the automatic bin alone. Just make sure you still have a 4Kppm signal to the ecm even if that means a Dakota digital sgi-100bt. I don’t know the effects of changing the flag. You might not have p/n adder if changed. Always learning more about $8d based masks . Just my two cents.
Car: 86 IROC
Engine: Twin turbo L31 HSR
Transmission: 4L80E in progress
Axle/Gears: 9 bolt 4.11
Good question...I have the EBL Flash 2, had a 700r4 and a JagsThatRun 2 PRS. I'm in the process of installing a 4l80e this winter with a stand alone controller, never thought if anything needed to be changed in EBL. Hmm.
Engine: Lb9
Transmission: M20
Iirc the flash 2 needs a 2k ppm. To prevent stalling and bucking and to maintain a good idle the ecm needs to have a Vss signal. Just not fully understanding the question to change the transmission flag
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
- Rob
