fan on idle surge stall solved
Old Feb 14, 2026 | 06:30 PM
drive it's Avatar
I I'm running the EBL P4 and just thought it worh throwing out there as it may help someone else. I'm running the EBL P4 and went thru a lot to settle the idle. But it still would surge and in certain conditions even stall when the fans came on. I have dual spal 11 inch brushed. on seperate relays turning on at the same time. I added in line on each the fan switch/relay from a mitsubishi lancer (from pickapart). Wired in between the original relay and the fan. It provides a soft start-slowly ramps up the voltage/fan speed over 5 plus seconds. The small wire input for PWM is left "capped" so it provides full speed. Completely solved the problem. I had been trying to deal with it in the tune and I found it impossible.
ULTM8Z
30
Nov 25, 2022 02:14 PM
ice_man0617
Aug 13, 2014 01:42 AM
onthedownlow
Jul 6, 2013 11:51 PM
restoIROC
Dec 30, 2002 03:07 AM
