RPM scale on Timing tables
Old May 31, 2026 | 04:25 PM
Vanilla Ice's Avatar
Car: 92 Trans Am Conv
Engine: LB9
Axle/Gears: 3.08
Has anybody else had an odd correlation with the timing tables when tuning? I've noticed two issues. First, when i correct timing, it doesn't work perfectly as it should. and two the rpms for some reason jump in 200 increments at first, then 400 increments lower down.
I checked the code. It doesn't do that. It's perfectly incremented for each cell.
Edit. I get it now. The table was correct. It's the datalogging parameter that's incorrect!
Old May 31, 2026 | 06:03 PM
Engine: LB9
Axle/Gears: 3.08
Re: RPM scale on Timing tables
Edit: nope. What a crazy haze I've been chasing a white rabbit methinks.
The good news is I'm working on more interesting hacks. Don't know if they'll be worth anything but if I didn't go down this rabbit hole I'd probably have it done and testing already...
Vanilla Ice
Dec 13, 2025 06:08 PM
skinny z
Jul 2, 2025 09:43 AM
Ronny
17
Jun 28, 2012 01:04 PM
87 Vette Owner
Jun 10, 2006 05:51 PM
Aaron's 87
Jun 10, 2001 01:56 PM
