Tuning tips and advice plz
Old Jan 28, 2002 | 07:03 PM
Astro4X4's Avatar
Try this again.
Hey guys,
I lowered my BPW number to get the block learn numbers between 125 and 127(up from where they were). Should I move it some more to get closer to 128 then tweak the VE table to get to the magic 128, or just tweak the VE tables? By lowering the VE numbers the ECM commands less fuel, right?, or am I backwards.
Old Jan 28, 2002 | 08:09 PM
ptc92rs's Avatar
Its been a while since I've done it but I'm sure your backwards. Low numbers = Rich Mixture, High numbers = Lean Mixture.
The closer you get to 128 prior to messing with the VE the better, or at least that is what I have found. The closer to 128 you are befor you begin the more accurate the base numbers will be.
Bubbajones_ya
Jul 6, 2024 08:32 PM
89 formula TPI
Sep 8, 2015 08:00 PM
Jlanz55
Sep 6, 2015 07:28 PM
mrdevontay
Sep 2, 2015 08:04 PM
