How To MAke Cooling Fans Come Sooner
Old Feb 12, 2002 | 08:21 PM
mystikkal_69's Avatar
Car: 1988 IROC-Z
Engine: L98 (350 TPI)
Transmission: MD8 (700 R4) + 3.42 LS1 Rear
Cooling Fans Come Sooner/ ARAP Question
in winbin under 3d-maps it has cooling fan #1 & #2. it also says in degrees and has two options. show calculated values and raw values? i would like the fans to come at 220 and off at 210. (i do lots of highway driving) what exactly do the raw values stand for and what do the calculated values mean(Deg Farienheit)? does anyone have a ARAP bin without Vats. i load that bin on my PROM and the car will not start. i load a stock bin and it start right up. this is on 88 IROC. thanks alot guys.
Old Feb 13, 2002 | 12:21 AM
Greenshamrock77's Avatar
raw values=hexidecimal code=what the ecm understands
calculated values=regular units (degrees, ect.)=what you understand
vats...
go into the flags tab, go to the "VATS & KNOCK Sensor Diag." menu and uncheck the vats bit, should do it.
Old Feb 13, 2002 | 06:44 AM
Car: 1988 IROC-Z
so for some unknown reason the flags do not work at all. Everything else is a ok. this is winbin 0.14 and under win98. take a look at the picture included. thanks for the info Green shamrock.
Old Feb 13, 2002 | 08:49 AM
TC602's Avatar
Car: 86 IROC
Engine: ZZ4
Transmission: T5 WC
Do you have the latest .ecu file for WinBin? If not jump over to Craig Moates site and download it. That should do the trick.
Tom
Old Feb 13, 2002 | 12:48 PM
Car: 1988 IROC-Z
thanks TC602 i owe you a 12pack. it worked like a charm with the updated ecu file. once again thnaks alot. :hail:
Old Feb 13, 2002 | 01:35 PM
Car: 1988 IROC-Z
Anyone know of a good 32B Definition File? the 6E wont work right?
Old Feb 20, 2002 | 01:20 PM
ZaphodB's Avatar
Car: Camaro IROC-Z '89
Engine: 350 TPI /w Procharger P1SC
Transmission: TH700R4 with Transgo shiftkit
Axle/Gears: 2.77 Borg Warner
http://www.area51.org.il/~zaphodb/gmecm/
Both the latest 6E and one for 32B....
RazorN8
Jan 7, 2022 11:44 AM
TheExaminer
Aug 26, 2015 04:59 PM
BlackphantomZ28
Aug 22, 2015 01:00 PM
gwade12
Aug 8, 2015 08:17 AM
Leggman1
Aug 6, 2015 04:15 AM
