Finally got it working with Craig's new software!!!
Car: Red Rooster
Transmission: M5
A friend of mine build me a Two Transistor cable and after a first try is has connected with both of Craig's software. So the first thing I did I used the 'dump' option to copy the EPROM image. I will view it later using WinBin.
Previously I could only connect with the older version. The newer is better and easier to operate. Craig did an awesome job on both of these programs. Thanks Craig.
Is there a help file somewhere that tells you what each of these values mean?
Car: 87 T/A
Engine: 441 SBC 12.5:1 0.680" Lift
Axle/Gears: 4.10 TruTrac Moser 9"
Take a look at the '165.dat' and '730.dat', that should give a brief description. Also Page-4 is rather descriptive.
backtothe80s
Sep 5, 2015 12:39 AM
