another winaldl log help some one
Old Feb 23, 2002 | 06:51 AM
missythehood's Avatar
what's wrong
File Type: txt
Old Feb 23, 2002 | 03:15 PM
well
please some one tell me what's wrong with my car
Old Feb 23, 2002 | 11:33 PM
JPrevost's Avatar
Car: 91 Red Sled
How about you tell US what's wrong with your car since we have no idea. I can't just look at the winaldl data and say...oh, yeah, you're having such and such trouble with such and such, looks like a hesitation around 1200rpm....., doesn't work that way.
First you tell US what is going on with your car since we don't know if your car is under water or just sitting in your driveway. All I could tell from the data was that the rpms were below 3000, you didn't move the TPS much and your o2 values look normal
Old Feb 25, 2002 | 02:10 AM
it stalls at low rpm all the time
Old Feb 25, 2002 | 03:25 AM
JPrevost's Avatar
Car: 91 Red Sled
Check your base timing, not enough and it'll stall. If it isn't getting enough fuel it'll also stall and backfire through the intake if you snap the throttle open real quick (while in gear).
Take more logged data. Looks like you're just running too lean, try cranking the fuel pressure up a little and play with the timing.
Last resort, go change your fuel filter. If you can't remember when the last time you did it or haven't...it's probably a good idea. Only like $6 and 15 minute job. Also adjust the fuel pressure and see if that cures the problem.
Cornholio7979
Sep 20, 2018 02:31 AM
L98GTA87
Oct 19, 2015 10:43 PM
89fast5oh
Sep 27, 2015 09:04 PM
BWilcox
Sep 20, 2015 12:19 PM
IROCThe5.7L
Sep 17, 2015 07:48 AM
