help code 55 and stalling data logged
Old Feb 28, 2002 | 03:08 PM
missythehood's Avatar
im stalling at low and high rpm help please i logged the data
i dont know what to do somone help please email me at missythehood@yahoo.com
File Type: txt
Old Feb 28, 2002 | 03:43 PM
junkcltr's Avatar
Engine: 3xx ci tubo
Transmission: 4L60E & 4L80E
How do you look at data in this format? I tried, but I can only look at data plots. I have a hard time just looking at the numbers. You might want to try and save the data in a format that can be more easily plotted. Personally, I think it is easier to diagnose problems.
Cheers,
J
Old Feb 28, 2002 | 07:08 PM
HighHopes85's Avatar
I don't know what scanner you are using, but the way I see it, your IAC is going full open in Park (or at least at 0 MPH). If it is full open, there are a myriad of problems that you could have. The most common is that the throttle plates are closed too far, making all of the bypass air go through the IAC passageways.
Set the minimum air rate.
Then scan again and stop revving it. Let the values stabilize. It is kinda hard to tell what the IAC really wants to do if your RPM is going from 800-3000 and your TPS is going from .7-66% -Matt-
BumpaD82
Feb 26, 2016 02:57 PM
IROCThe5.7L
Sep 17, 2015 07:48 AM
amcnellis
Sep 16, 2015 04:16 PM
rjcme
Sep 5, 2015 01:23 PM
