Craig Moates, need your help
Old Feb 27, 2002 | 01:17 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
Craig,
I have downloaded your beta version (8.5). Used WinZip to extract the files. Now I have a Moates directory with about 50 files in it.
Now what do I do????
Please consider me a retard. You will have to give me detailed step by step directions.
How do I get you software program going?
What cable do I use to connect my laptop to the OBD port on my '87 Camaro?
Old Feb 27, 2002 | 02:04 PM
craiger's Avatar
I copied the files to a floppy, then installed the floppy in my laptop, then copied the files to my c drive. Then go into dos and enter ecm845
Old Feb 28, 2002 | 07:54 PM
Craig Moates's Avatar
Car: 87 T/A
Engine: 441 SBC 12.5:1 0.680" Lift
Axle/Gears: 4.10 TruTrac Moser 9"
Check the 'readme.txt' file, should have information in there.
Also, there should be some schematics on my site which detail designs that work. Try any one.
- Explore the directory you opeed, and then double-click the 'startrun.bat' file. This will run it. Either that or get the 845 like mentioned previously.
Hope this helps!
-Craig
UltRoadWarrior9
Apr 28, 2020 10:39 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
ZZ42Fast
Aug 30, 2015 02:39 PM
