What is DFCO?/COLD START?
Old Mar 8, 2002 | 05:28 AM
RBMZ28's Avatar
Car: 87 IROC (low 12's)
Engine: 400 sbc .040 over
Transmission: 700r mod
What does dfco do?And where and how do address cold start?
(thanks grumpy,you got me going on this question).
Old Mar 8, 2002 | 09:51 AM
afgun's Avatar
Car: Non F-body :(
Engine: Pontiac 301
Transmission: TH350
I believe DFCO means deceleration fuel cut-off.
Old Mar 8, 2002 | 11:33 AM
GregWestphal's Avatar
Car: '87 Camaro IROC-Z
Engine: 385 HSR
Axle/Gears: 3.42 posi
DFCO (Andrew's definition is correct) is when the computer shuts off the injectors (pulse width equals zero) when slowing down. There are several parameters that must be met for it to be enabled and several more to remain in DFCO, mostly relating to vehicle and engine speeds, LV8 or MAP value, and %TPS.
Cold start (I'm assuming you're talking about fuel) is addressed in the open loop %change to AFR tables (one vs. coolant temp, the other vs. LV8 or MAP).
Orr89RocZ
Apr 25, 2016 08:28 AM
Wade787b
Sep 29, 2015 01:15 PM
dyeager535
Aug 28, 2015 08:10 AM
SolarGoldRaptor
Carburetors
16
Aug 25, 2015 02:25 PM
92camaroJoe
Aug 13, 2015 06:07 AM
