Help!!!!
Old Mar 8, 2002 | 11:13 PM
rooster433's Avatar
Help!!!!
Hey guys I've got a 93' LT1 which requires the same programing as you guys.
I've got a Pocket programer and tunercat. oh and i'm using an 28 pin header as an adapter. (like the tutorial on this website)
Well somehow i've toasted 3 memcals in the past week.
I'm not sure as to how or why, but you put the memcal in the car and you get a solid SES light and no diagnostics communtication. It seems to run okay sorta but speedo doesn't work either.
Whats wrong with my memcals? the first one lasted 11 erasures/programs. the last two only lasted 2 times.
I'm not really overcooking my eproms, and i'm being careful to ground myself. Does anyone have any idea what might be going on?
Old Mar 9, 2002 | 02:01 AM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Re: Help!!!!
Leaving as much of the legs as possible cut the eprom out of one of your dead memcals, and solder a ZIF socket in it's place so you cna use eproms instead of memcals.
Off hand sounds like the wrong programming voltage.
Old Mar 9, 2002 | 06:20 AM
rooster433's Avatar
I'm using 12.5v on the PP2 what am I supposed to use?
Have any of you guys seen flaky PCMs that don't like certian memcals?
I'm constantly touching door **** and the back of my computer case to try to ground me.
Old Mar 9, 2002 | 09:21 AM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
The problem with eproms is they have a limited life. Or more exactly, they can only be exposed to UV light so much. I found by carefully managing the erasing time (long enogh to properly re-program but not so long to "over erase") would maximize the number "re-writes", but I never got more than 50 reburns.
The best thing to do is remove the eprom and install a ZIF socket as Bruce suggests and then go to the AT29C256 Flash Prom. Flash Proms have a significantly longer re-write cycle. Depending on temp etc, it can be anywhere from 1,000 - 10,000 times.
Flash Proms are the only way to go. My UV eraser is now only for a "conversation" piece.
Old Mar 9, 2002 | 11:57 PM
Craig Moates's Avatar
Car: 87 T/A
Engine: 441 SBC 12.5:1 0.680" Lift
Axle/Gears: 4.10 TruTrac Moser 9"
Fear not, stuff's on the way...
-Craig
