want to get started burning my own chips
Car: 86 SC Camaro drag car
Engine: 406
Transmission: Th350
Axle/Gears: 8.5 10 bolt 4.10
I have been stashin loot and am ready to start getting all the stuff required to burn. I have the download page with everything listed and just wanted to be sure this was still current...as in no updated equipment availible now that is better, easier to use etc.....thanks
Car: 90 IROC
Engine: 406
Transmission: GMPP 93/4L60
Axle/Gears: 9 bolt 3.27
Make sure you use the AT29C256 Flash proms. Craig Moates ZIF to ecm adapter works great also. I wish I would have started long ago its much easyier than I thought it would be to burn proms.
I would not buy the UV eraser, instead I use Flash Prom's that will programme directly from the PP. the AT29C256 is a direct replacement for the 27C256 EEPROM installed in your current memcal, I have done this to several memcals and they all work great. Mike
Engine: 406
Transmission: Th350
ok, will the AT29C256 plug into the carrier that came with my hypertech chip??? the prom comes right loose from it so I thought maybe I could just use it instead of a ZIF?? So you can just program right over a flash prom without erasing it then??? Sorry I am really new at this, guess I need to do a lot of homework first.
Car: Death Mobile
Engine: 666 c.i.
Using a ZIF socket and then just pulling the prom will only result in accidentally bending/breaking a pin. A damaged eprom/flash prom is a lot cheaper than a damaged Memcal and/or ECM.
