what are the effects of disabling CCP?
Old Mar 31, 2002 | 06:50 PM
Synapsis's Avatar
Car: Sexy
Engine: Stock
Transmission: Slipping
I'm trying to tune my BLMs and I'm having the hardest time. I disabled my EGR, and drove around for an hour to get a good bit of data. I've noticed that whenever the CCP duty cycle is more than 0, I go pig rich.
I know that disabling the EGR can cause detonation (I've noticed a slight increase in retard when running lean in OD), but is there a problem with disabling CCP?
Old Mar 31, 2002 | 09:35 PM
SMasterson's Avatar
Car: '89 GMC Pickup
Engine: 383 SBC Stealth Ram
Transmission: 700R4/VIG 3200
Setting the 'Canister Purge - Map Enable' in the 730 8D too high got me stuck in cell 4 (idle cell) and took me all day to figure out what was wrong. I made too many changes at one time so I went back a few burns and started again.
Look in the anth_hac.pdf on page 39 and you'll see a reference to it. I don't understand it all yet but I'm looking up issues as they come up.
L8522 FCB 51 FORCE IDLE CELL LRN IF CCP DC LT 51
I probably was thinking along the lines you were. If I disable things I'm not using that the ECM adjusts for I'd get a better calibration. For now, I just put it back where it was.
Oh, there are other constants in the bin that can do the same thing but I didn't try them.
Old Apr 1, 2002 | 12:06 AM
Synapsis's Avatar
Car: Sexy
Engine: Stock
I edited my BIN with WinHex to change that force idle cell lrn to 0. I started it up and it behaved like a bad bin.
Is there a computed checksum somewhere that I have to update?
Old Apr 3, 2002 | 12:22 PM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Sorry for interrupting but I did a search and came up here.
what are CCP's? I was scanning my car yesterday trying to find out why i'm getting such poor gas mileage. I noticed the EGR was at 100% (normal?) and I believe the CCP was at 30.
From what I gather 100% EGR is good. But I'm still lost on the CCP's.
Help?
Old Apr 3, 2002 | 12:41 PM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
CCP = charcoal canister purge?
is 30 bad for the number?
Old Apr 3, 2002 | 01:56 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
As far as I know those numbers are Dury Cycles for the operating solenoids.
As you run larger and larger cams, you have more self egr'ing, due to the change is in overlap.
On the CCP, it's to some degree a vacuum leak, so you need to moderate it so that the ecm corrections can account for that. The amount of vacuum leak varies with the vapor content of the canister.
Old Apr 3, 2002 | 04:10 PM
87_TA's Avatar
I dont want to sound like an idiot but i have taken off my purge canister.
do i need that other than for imissions?
currently the line from the tank to canister is just hanging out ,
should i plug this? should i run a small vacuum to it?
i do notice my gas tank always has alot of preassure upon taking cap off,is this why?
jovibuilt
Exterior Parts Wanted
Oct 18, 2015 08:12 PM
Damon
Sep 26, 2015 04:29 PM
James Sutton
Sep 23, 2015 01:56 PM
billybob6110
Sep 23, 2015 01:30 PM
