Blinker
Old Apr 14, 2002 | 10:48 PM
jeff85iroc's Avatar
Blinker
My left front blinkers will not work.
All the rest are ok except the left front.when i put the hazzards on it's the same thing.
I checked if it was the globe holder but it was not because i spliced in to the wires about six inches futher up the wire with another globe and that did not light up.
So i am Guessing that there is no power at all going to those wires.
Something new is going wrong every day i can't believe this.
Any help appreciated.
Jeff
Old Apr 15, 2002 | 02:52 PM
mtccl's Avatar
Check the bulbs. Bad bulb results in no flash on that side. make sure you use the correct amp bulb also. Others will fit, but they will overheat and blow out.
Old Apr 16, 2002 | 07:00 AM
jeff85iroc's Avatar
No bad bulbs,correct bulb and still did not work so i just run another 2 wires from my rear blinker.
Jeff
RABMAN
Interior Parts Wanted
Sep 18, 2015 09:02 PM
Jk_Under
Sep 2, 2015 10:59 PM
bklucas12
Jan 11, 2002 06:44 AM
super83Z
Jun 2, 2001 10:44 AM
Jimmy91RS
Sep 28, 2000 02:16 PM
