Turn signal
Old Jan 10, 2002 | 11:09 AM
bklucas12's Avatar
Turn signal
My left turn signal will not work, in the dash the left blinker just stays solid and doesnt blink when I turn it on. The left blinker in the front of the car works, but it doesnt blink, and the blinker in the rear doesnt even light up. so I went to advanced auto and bought a new light. put that in and it still was solid, they guys there said it was probably a bad blinker, and gave me this round part with 2 prongs sticking out of it, when I asked where it goes they were sudenly very short and mumbbled something and quickly ran off so I was kind of upset but its not there job anyways. To note the right blinker works fine... any suggestions, and where does this round thing go.. install to? I looked all over my fuse box couldnt find it
thanks
Old Jan 10, 2002 | 11:51 AM
82camaro's Avatar
Car: 82 camaro SC
They gave you a flasher. The flasher is fine if the other blinker works--they use the same flasher. Every bulb needs to be working for the blinkers to blink. Check them all using the right blinker lights as a guide. Also, make sure they got you the correct bulb. Other bulbs may work, but aren't powerful enought to make the flasher kick in and out.
Old Jan 10, 2002 | 09:40 PM
BuddyLeeX's Avatar
Car: 06 Toyota Tundra SR5
mine does teh same thing, except a couple weeks later it will start to work again, it seems to screw up a lot at night when i turn on my lights, I think my signals are demented.
Old Jan 11, 2002 | 06:44 AM
1986redbird's Avatar
Blinker
check the rear light bulb on the side that does not work, if one bulb is out the whole side does not flash.
83 Crossfire TA
Jan 3, 2016 01:26 PM
bbsr72
Sep 27, 2015 05:55 AM
TrevinE
Sep 14, 2015 03:20 PM
83 Crossfire TA
Sep 8, 2015 12:06 PM
