82 transam tuneport swapping questions
Old Apr 16, 2002 | 08:58 AM
MarkB's Avatar
Car: 1982 T/A -1986 Z28
Engine: 383 -305
Transmission: T56-700r
ok..ive recently aquired a complete 86 tpi system off of a 1986 z28 305 TPI car..came with the complete wiring harness of the ENTIRE car.my questions are..when i get the TPI installed..what am i going to do about a check engine light..so i know when somethings screwing up on me? can i just wire it into my stock 82 gauge cluster somehow? so that when it throws a code..a light comes on or something so that i know somethings gone **** up?
Old Apr 17, 2002 | 12:53 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
You can pull the wire out of the old SES lamp driver, and feed it directly from the ECM for an SES light. I think a wire from the ALDL goes to the SES too.
Your dash plugs should be similar to mine...
Code:
  TPI (86 LB9)               MONTE
A BRN           436          BRN           436
B RED/BLK       ???          ORANGE        440
C BRN/WHT       419          WHT/DK.GRN    487
D BRN           120
E WHT/BLK       451          WHT/BLK       451
F PNK/BLK       439          PNK/BLK       439
G PNK/BLK        39
H TAN/BLK       422          TAN/BLK       422
J ORN           461
K BRN           437          BRN           437
L
M BLK/WHT       450          BLK/WHT       450
N ORN/BLK       434          ORN/BLK       434
P PPL           420          PPL           420
R PPL/WHT       806
which pretty much means you'll directly connect A, E, F, H, K, M, N, and P, but have to figure out the others w/ the factory 86 Camaro wiring diagrams.
You'll be running a new wire to the fuel tank (get a tank & sending unit from an EFI F) but re-using the old ground there, and the rest is fuzzy, but you did very well getting a complete factory setup; that's the way to do it.
Matthew
Old Apr 17, 2002 | 01:04 PM
MarkB's Avatar
Engine: 383 -305
hey jmd..i noticed in your sig you have a mechanical clutch'd world class t-5..i too have a world class t-5 in my 82 transam..which was stock 305 4spd stick shiftcar..and has the stock mechanical z bar/pushrod clutch setup. my question is..how does your tranny shift..hows the clutch engage..disengage..smoothly? im having a bit of problems with mine..it seems to pop 3/4 the way down..but i beleive i have the wrong pressure plate and disc..any info you can lend as to your specs and stuff? it would be greatly apreciated..thanks
MarkB
Old Apr 17, 2002 | 01:27 PM
jmd's Avatar
jmd
Hey Mark.
Everything in my linkage is g-body except the lower pushrod (Chevelle) and the fork/bellhousing/trans. is f-body.
I had to tweak the lower arm of the z-bar because it went right into the O2 of the hooker headers (PN 2050) but it seems to clear fine now
I really haven't put many miles on it since October when I put the mechanical stuff in w/ a new Ram clutch, but the "hitting O2" didn't allow full throwout so it's been "annoying" but we'll do some driving this week and see how it works. I expect it will be fine.
I used to have the hydraulic 84-92 f-body setup and it was sweet.
My friend Bob is doing a Tremec into his Monte and Centerforce told him that their 84-92 PP is different than the one for an 83 (which was mechanical) so there may be some reason for your trouble....
Matthew
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
theurge
Aug 21, 2015 12:46 PM
jharrison5
Aug 19, 2015 05:53 PM
redmaroz
Aug 16, 2015 11:40 PM
reiderz iroc
Aug 13, 2015 04:57 PM
