MAF Values???
Old Apr 23, 2002 | 04:04 PM
87IROC350HO's Avatar
MAF Values???
Any one know of what the MAF sensor values are? or how you tell if the MAF sensor really is bad? Thanks in Adviance
Stan
Old Apr 28, 2002 | 08:43 PM
89Warbird's Avatar
Car: 1989 GTA Nighthawk
Engine: 389 CID TPI
Transmission: TCI 700R4
Axle/Gears: 9 bolt 3.23
Mine just went bad. First it just started running like crap, couldn't figure it out, didn't want to idle, surging. Then it started popping the MAF code so I started watching the numbers. Normally showing 9-11 g/sec at idle, new MAF shows 8 g/sec at idle and all is WELL again. Wells MAF SU-145.
Old Apr 28, 2002 | 10:30 PM
thanks for the response...what is "g/sec" and how did you measure it?
Stan
Old Apr 29, 2002 | 03:25 AM
Jza's Avatar
Jza
g/sec is "grams per second". It's measured with a diagnostic scantool that plugs into the ALDL port under the dash. Scantools cost anywhere from $100-$500 for DIY mechanics, and more for professional models (up to a couple grand). There are, however, several free/semi-free programs you can download onto your computer or laptop, and build a cable from a few dollars in parts and some work. They can do everything the more costly scanners can, and some can do much, much more. Check out the DIY PROM board, and search for Craig Moates' scan software, and JoBy's WinALDL scan software. These are in invaluable tool for diagnosing and tuning any EFI thirdgen. :rockon:
Mark_ZZ3
May 24, 2018 01:02 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
racereese
Oct 3, 2015 03:46 PM
