wiring up dual fans from a Lumina?
Old Apr 29, 2002 | 10:28 AM
Matt86Z's Avatar
My fan's singing it's death song (Wheeeeeeeeeeeeeeeeeeongongeeeeeee) and I'm wondering if a set of two (slightly) smaller fans from a Lumina would work just as well? The fan that's on it is hotwired to the ignition, and I want to set one of the new ones up in the factory manner...Some creativity with some sheetmetal, some wiring, a relay, a switch for the second one...Anyone have any experience?
Old Apr 29, 2002 | 04:47 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
I wouldn't think the size would make much of any differance (except maybe a slightly less elec draw on the car).
Here's a simple diag of a non-ECM controlled fan (LG4, TBI). The only other thing on the green/white ground wire (spliced inline) would be a ground (green wire) from the HVAC controls to kick the fan on when you turn on the A/C
*edit, oh yea, the fan switch goes/is in the pass. side head.
Old Apr 30, 2002 | 12:20 PM
Matt86Z's Avatar
Thanks, DB. Can I run power off the fuse block for the relay, too, or does that need to come directly for the battery?
Example: my fogs and relay are run off ingition power from the fuse block.
Old Apr 30, 2002 | 04:12 PM
deadbird's Avatar
Engine: TPI 305/ v6
If you're talking the +12v to power the fan itself, technically, you could but, personally, I'd run the wire from the battery. 1, less taxing on whatever circuit you're tapping into on the fuse panel (plus the circuit wiring might not agree with it.. i.e., burnt up wiring/possible elec fire) and 2, it's a shorter distance to the battery & no firewall to go thru.
eightsixseven
Dec 16, 2024 01:50 PM
RazorN8
Jan 7, 2022 11:44 AM
Ikes 91Z
Dec 9, 2015 03:49 PM
Scamo-2.8
Dec 5, 2015 09:16 PM
thefirebirdm@n
Aug 25, 2015 05:21 PM
