RPM window switch help??
Old Apr 30, 2002 | 09:29 PM
onebad82z's Avatar
Car: 1982 Z28
Engine: 355
Axle/Gears: 12 Bolt
Ok..I finally installed my NX system in my car,ran fuel supply,wired up NX relay,solenoids,MSD window switch and all that fun stuff.Start car,arm system,rev it past 3,000rpm which should activate system with friend holding WOT closed....nothing.I have the NX relay grounded to my FPSS set to activate at 4psi,and the other side of FPSS grounds through the window switch(yellow wire),otherwise wired as per NX instructions.I have wired up the window switch as per MSD instructions with my 6AL and have hot wired both solenoids to make sure they do work just to be sure,they do.Should I send this thing back or is there something simple I overlooked before returning it?
BRoss99
Aug 10, 2025 05:08 PM
1992 Trans Am
May 10, 2023 07:19 PM
stalkier
Aug 21, 2015 01:54 AM
Dialed_In
Aug 20, 2015 01:45 PM
Wylecoyote08
Aug 14, 2015 08:28 AM
