OK I may have found the problem...let me know if i did this right please
Subscribe
May 6, 2002 | 11:44 AM
ok i took my multimeter and the coil is definetly getting voltage 11.1-11.9 the line that goes from the coil to the igintion module will conduct...but i dont know if i did this right but the batt to igintion module line isnt getting any volts with the key turned on...i just have it set on volts so i dont know if thats right or not. also i think the distributer is working or something is crazy because if i turn the distributer (had it out so its loose) it will fire the injectors if i turn it back and forth...WTF is up with that? does it sounds like im not getting fire because of the batt to igintion module connection maybe?
Reply 0
May 6, 2002 | 06:07 PM
Did you check to see if you are getting juice to your spark plugs? To do this just unplug a wire from any plug and see if it sparks as you turn the distribuitor.
David
Reply 0
Subscribe
