Anyone know how to wire a horn?
Old May 10, 2002 | 09:11 AM
cllimp101's Avatar
I have a 85 camaro z-28 and i cant get the horn to work? Does anyone have any wiring diagrams on it or anything at all about it? THnx Craig. I have a gt grant steering wheel if that matters let me know thnx
Old May 10, 2002 | 09:43 AM
92RSB4C's Avatar
http://92b4crs.tripod.com/86wiring/dia-pics/40-0.jpg
Here's the diagram for an 86.
Old May 10, 2002 | 04:43 PM
Flamingo's Avatar
Car: 89 GTA
Engine: 5.7 TPI
simple checks
Do you know if the horns work? There should be one wire that comes off of the horn, connect that to +12 to make sure the horn works. Check the fuse? Did the horn work before you put the Grant in? Has it worked since you put the Grant in? There is a wire that comes up through the steering column, believe it is yellow, that connects to the horn pad.
92RSB, couldnt get that screen to load. And I was just looking thru my Haynes, and it doesnt really have anything about the horn.
Old May 10, 2002 | 07:05 PM
cllimp101's Avatar
:hail: Thnx for the reply but i just bought the car 2 weeks ago and it had the steering wheel on it alrady so i never tested it or asked the seller about it. Also where is the actual horn i cant find it? Sry i sound like a moron but i can seem to find it anywhere and i looked in my chilton and it didnt have any thing on it i could see. Thnx again Craig
Old May 10, 2002 | 11:00 PM
Jza's Avatar
Jza
Look practically "inside" the driver's side fender towards the front. You should see two nautilus-style horns mounted on a bracket near a vacuum reservoir.
If you have one of the cheaper Grant wheels with the big horn button, there's a good chance the previous owner disabled the horn because those wheels have a notorious problem of the button popping off and letting the horn blast until you realize it's your car making all that racket and go out there to fix it.
Old May 12, 2002 | 03:11 PM
Tonyrodz's Avatar
Transmission: auto
Here's something simple--did you pull the horn button off(steering wheel) to see if the wire was attached? It might be just hanging off. Hopefully it's that simple.
Old May 15, 2002 | 10:07 PM
BOTTLEDZ28's Avatar
Transmission: A4
proper way to wire up a horn
1. lower window
2. extend left hand
3. give the finger
4. retract your hand
5. roll up window
there all done point got across and it was free
Caspar
Jun 19, 2016 11:19 PM
ndndndnd
Carburetors
17
Sep 5, 2015 06:24 PM
Bryan F
Aug 27, 2015 07:28 AM
Stauf
Aug 24, 2015 08:31 PM
Keiffer76
Car Audio
Aug 9, 2015 11:37 PM
