Guage problems Tpi to Carb????
Old May 12, 2002 | 02:24 PM
FatOne's Avatar
Have a 85 Z28 that had 305 Tpi. Now I went to 350 with Carb setup. My problem is when I got it back from the shop. The fuel and oil press is not working. The needles are all the way maxed out on the guage. Did someone mess with the needles you think? How should I correct this. I have now idea how the wiring would go now. They totally took out my elec. fuel pump. Put in a mech. on the block. Is there a wire that leads from tank to the guage. Also what wires do I need for the oil pressure? One thing also is that they rigged up my elec fan to be on all the time. From ing. turn to shut down. Is this setup ok for now? If not how should I correct this? All the other guages tach, batt, temp, mhp. They all seem to be in fine order???? I need help and would like to use the old guages if possible. No after market crap.
Old May 12, 2002 | 03:36 PM
Morley's Avatar
Sounds like they grounded out the wires to the senders.
~M~
Old May 12, 2002 | 08:47 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Actually when they peg, the connection to the sensor/sender is open (not connected). My oil psi gauge is pegged on my camaro because there is no sensor/sender for it, if you touch the wire to the block, it drops to 0.
Make sure there is a small 'bell-shaped' canister at the back of the intake (oil press gauge), if there make sure there's a wire attached.
There is a small weatherpack plug about where rear axle on the metal (where the backrest of the rear seats are), originally the fp/gauge sender (3 wires total) were plugged in there. The gauge wire is pink according to the diagram.
Old May 13, 2002 | 10:23 PM
FatOne's Avatar
Thanks for the tips I hope that I can get it working alright. Also anyone know about this elec. fan hook up? It seems kinda shaddy to me?
Ghettobird52
Jul 5, 2024 11:18 PM
Infested
May 22, 2018 11:56 PM
theshackle
Mar 5, 2017 06:37 PM
86IROC112
Aug 17, 2015 02:00 PM
Sanjay
Aug 12, 2015 03:41 PM
