Code 33 & 34 Help!!!!
Old May 15, 2002 | 09:19 AM
trd51398's Avatar
Hey Everyone,
I have been doing some searching on the board and couldn't find anything that really helps. My check engine light on my 88 Iroc with the 350 came on the other day and has been doing it constantly now. Once the light comes on it feels like that the car is alittle sluggish. I checked and code 33 & 34 come up. I know they have to do with the MAF & MAP sensor. ANy help you can give me to solve this without replacing the MAF sensor would be great.
Old May 15, 2002 | 09:29 AM
92RSB4C's Avatar
Hmm, You'd better replace the MAF sensor.
Old May 17, 2002 | 07:56 PM
RBud350tpi's Avatar
This is the whole reason I converted to speed density on my 89. look over the schematics and find the dark blue wire on the maf sensor. when you shut the car off you should get 12v at the wire for a few seconds. this is the burn off function of the maf. the 12v heats the wire in the maf and any trash or carbon that builds up on it gets burnt off and injested next time you start the car. this is the most common cause for problems with the maf and code 33/34.
Rich
Old May 19, 2002 | 01:52 PM
quiksilver1j's Avatar
I have the same prob. i get code 32, and 34 my car will be drivin and then all of the sudden i can't drive but the car doesn't stall.
also the car seems sluggish
Old Jun 2, 2002 | 12:00 AM
Shagwell's Avatar
Car: projects.......
My books at work(Autozone) show code 33 to be high voltage MAF. I just had the same problem, but for me , it turned out to be a crappy solder job by yours truly after gutting the MAF.
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
dusterbd
Sep 29, 2015 08:40 AM
