LEDs
Old May 15, 2002 | 01:38 PM
CHCKLS's Avatar
Car: 89 Iroc Z Cnvertible
Engine: 409 SR
Transmission: 6 speed
LEDs
How do you determine if any what resistor you need for how many LEDs?.....
Old May 16, 2002 | 06:01 AM
Blackened's Avatar
There's a formula and it ALL depends on the specs of the LED. Like how much current it can handle and what the normal voltage drop is on it. Post that info and I'll show you what I mean.
Old May 16, 2002 | 05:14 PM
racereno's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Axle/Gears: Stock
Hey Frobozz, talk to him. Blackened knows his LEDs!
Old May 16, 2002 | 05:37 PM
86IROCZ's Avatar
Without the LED's,
It'll be very dark and you're likely to get eaten by a grue.
"Frobozz" Haven't seen that reference in years. I think I'll go play some ZORK!!!
Old May 16, 2002 | 05:44 PM
racereno's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Axle/Gears: Stock
WOW, excellent trivia 86IROCZ! I haven't thought of Zork since the Commador 64 days. Everybody get out your big floppies and play!:sillylol:
Old May 17, 2002 | 07:14 AM
CHCKLS's Avatar
Engine: 409 SR
AH, there are some fans of the famed Infocom game out there
I have'nt gotten any LEDs yet as I am just now in the planning stages and thought there might be a way to know ahead of time what and how many LEDs I would need for my project. I pick on eup today just so that I post about it and go from there....thanks.
Old May 17, 2002 | 06:01 PM
Twistopher's Avatar
Car: 91 Z28 Convertible
Engine: 305TPI
Blackened: What are the specs on the LEDs you are using for your Blue Dash?
Old May 18, 2002 | 12:07 AM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
Engine: 350, ZZ4 equivalent
Transmission: Pro-Built Road Race 700R4
Axle/Gears: 3.23 Dana 44
For 1 LED or multiple LED's wired in parallel:
+V-(V led)
Rs = ---------------
Iled
Rs = The ohms of resistance needed (the resistance value of the resistor)
+V = Input voltage (About 13.45 volts in my car)
V led = The volts the LED is rated at (mine were 5v)
I LED = The amps the LED uses (mine was .02 or 20mA)
Example:
13.45 - 5
Rs = --------------- = 422.5 Ohms
.02
For 2 LED's wired in series:
+V-(V led)
Iled + Iled
Example:
13.45 - 5
Rs = --------------- = 211.25 Ohms
(.02 +.02)
Old May 18, 2002 | 12:08 AM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
spaces don't show up on this form so goto http://www.apmracing.net/old%20site/lukeS/led/LED.htm to see the formula's
Old May 19, 2002 | 09:40 PM
CHCKLS's Avatar
Engine: 409 SR
Got another question about this and the tech article above.
If you tap off the positive and negative leads on the circut on the back of the gauge cluster, why can't the leads be dimmed?..
Is there a way to make the LEDs dim as the original bulbs did before?.....
Thanks.
Old May 20, 2002 | 05:01 AM
Blackened's Avatar
There IS a way to dim them if you use sort of of voltage regulator circuit that's electronically controlled by the **** in the headlight switch. Too much "drama" for something you don't REALLY need. How many times to do adjust the brightness of your dash ? lol
LiquidBlue
Wheels and Tires
32
Dec 10, 2019 04:06 PM
RedLeader289
May 28, 2019 01:47 PM
Fronzizzle
Feb 9, 2017 09:31 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
