More trouble shooting, ATTN: Tim Burgess
Old Sep 16, 2000 | 04:43 PM
Bill91Z
Guest
Posts: n/a
Tim I re-read your response to my first post and check the security light to see if it would point me in the right direction. I first bypassed the system using the correct resistors and still nothing. Checked the light and it does come on for about 2 seconds then shuts off as it is supposed to, meaning, the contacts in the column are hitting the key and that is not the problem, correct?
Where do I go from here?
Just to recap: New starter, new VATS relay, VATS bypassed but still nothing.
VATS it's now re-hooked back up to it's original configuration.
Thanks in advance
-Bill
-=ICON Motorsports=-
Boston Chapter
91Z28, (in progress) 3.8L, TE63-1 turbo, MSD50lb injectors, Hemco upper, ported TTA heads, 62MM TB, Red's XP fuel pump, 3.73s, vigilante (stall to be determined)
Old Sep 17, 2000 | 03:37 PM
Tim Burgess's Avatar
Car: '92 Z28; Dk Teal; Her Pkg
Transmission: Richmond 6 Spd
Axle/Gears: Moser 9", Detroit Locker, 3.70
Bill,
You are correct - the VATS appears to be functioning properly. Here is the path of the power that goes to the starter solenoid when the ign switch is in the start position. Start by measuring the voltage at the yellow wire, with respect to ground, on the VATS starter relay, with the ign switch in the start position, and progress from there to determine why the starter solenoid is not engaging. If there is no power at the yellow wire of the VATS relay, then the ign switch is probably bad.
Check the following locations for voltage with the ign switch in the start position:
Yellow wire to VATS relay (start power from ign switch)
Dk green wire from VATS relay (start power to gear selector switch (automatic) OR clutch start switch (manual)
Purple wire from gear selector switch or clutch start switch (start power to starter solenoid)
The gear selector switch is in the center console, and the clutch start switch is behind the clutch pedal lever.
Tim
Old Sep 17, 2000 | 03:46 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
Yes, Tim has it. you need to find out where you have voltage, and where it drops off and that will pinpiont where the problem lies. Just remember all the measurements must be done whith the key in the crank position. Good luck.
"I used to have a handle on life, but then I used it as a plunger and broke it" -The Wave
ASE Master Tech + L1
Savannah, GA
'87 Trans Am-K&N,Cold air induction, SSM SFC, Boxed LCAs, 8mm Accel wires, Flowmaster, 16" GTA rims.
'97 Bonneville SSE
If you live in Southeastern US, check us out!
South East Thirdgen
RedLeader289
May 28, 2019 01:47 PM
Bubbajones_ya
Oct 25, 2015 08:01 PM
meeklay812
Oct 1, 2015 03:46 PM
3.8TransAM
Sep 27, 2015 08:37 PM
Lmancha96
Sep 25, 2015 08:11 PM
