attn: TIM BURGESS too
Old Sep 17, 2000 | 03:54 PM
Black Beauty's Avatar
Car: 90 Camaro RS
Engine: 305 TBI
where do i connect the neg terminal to the ignition power??? thanks
rick
Old Sep 17, 2000 | 05:04 PM
Tim Burgess's Avatar
Car: '92 Z28; Dk Teal; Her Pkg
Transmission: Richmond 6 Spd
Axle/Gears: Moser 9", Detroit Locker, 3.70
A good place to get ign power under the driver's side kick panel to power the manual TCC lock up switch light bulb would be the pink / blk wire from the 10 amp gauges fuse, since it powers the brake pedal operated TCC switch. An easier place to access that wire might be right at the TCC power switch, by the brake pedal. It is the rearward most plug, of the two on the switch, with the purple & pink / black wires going to it. Use the pink / blk wire.
Tim
Kevin91Z
Southern California Area
22
Sep 19, 2022 10:00 AM
timonator
Sep 17, 2015 06:57 PM
SG91camaro
Sep 5, 2015 10:27 PM
TheExaminer
Aug 19, 2015 10:07 PM
Willie
Jan 18, 2001 06:03 PM
