Wiring in a manual fan switch
Old May 17, 2002 | 03:44 PM
uk89camaro's Avatar
Gents,
Before you flame me, I have spent a fair amount of time researching the issues around wiring in a manually activated fan switch. But I am still confused. (I don't understand most of the posts that relate to this issue!)
This is what I want to achieve :
1. Install a 12v LED that shows when the fan is activated in normal circumstances.
2. Install a manually activated switch that allows me to run the fan as I wish (and activates the LED)
3. Retain the normal fan operation if the manual switch is off.
To help me achieve this I would like you to tell me exactly which wires I need to splice into, etc...
We're talking an '89 305 RS LO3, single fan. It runs just fine, but I'd like the manual intervention if required.
:hail:
Old May 17, 2002 | 04:35 PM
92RSB4C's Avatar
Just go to an electronic store and buy a lighted switch. It has 2 inputs (12V and Ground) and 1 output (ground). Im not real familiar w/ LO3s so I cant really tell you how to do it. If you run a 12V source off of the fuse block, make sure to put it on the "Radio" outlet.
Old May 17, 2002 | 08:14 PM
NXS055's Avatar
i've recently done this (except for the LED, I'd love to do that though)
what I done was just run a wire from the "fan" spot on the fuse box, then run that to the switch, then run a wire from the other side of the switch to the wire going to the fan motor... it is a black wire and has a red stripe... it is in a piece of plastic conduit so you'll have to cut that....
its really quite simple....
when I flip the switch the fan comes on, with the switch in the off possition it works just like stock....
now, about the LED... I don't know much about them.... looks to me like you could loop a wire from the side of the switch that runs to the fan to itself... like splice it in at the switch and then 4 inches out on the wire splice it back in, making a loop... just put the LED in that loop and when power is applied to that side of the switch it should come on.....
this is what i'm assuming, I don't really know.... I plan to try it, I just havn't gotten around to it yet....
i know the switch part works, but the LED part i'm not sure of....
i hope it helps
Old May 19, 2002 | 01:35 AM
uk89camaro's Avatar
Guys,
Thanks for the advice, much appreciated.
I'll come back to you on the LED.
eightsixseven
Dec 16, 2024 01:50 PM
1992 Trans Am
May 10, 2023 07:19 PM
RazorN8
Jan 7, 2022 11:44 AM
89GTAOz
May 16, 2020 09:31 AM
TA8487
Aug 16, 2015 12:21 PM
