MSD 6AL ?'s
Old Sep 13, 2000 | 07:07 PM
IROCET's Avatar
Car: 88 IROC-Z (Sold)
Engine: 5.7L
MSD 6AL ?'s
I recently purchased a MSD 6AL ignition for my 88 IROC. I noticed that it makes a sort of buzzing noise which increases with the rpm. Is this normal? Also, where is a good place to mount this thing? Thanks
Matt
irocet@hotmail.com
drive.to/Stang_Kilr
88 IROC-Z -- 350 L-98, 700R4, Flowmaster, K&N, MAF Sceens Gone, Airfoil, March Pullies, Comp Cams Magnum 1.6 Roller Rockers, Accel U-Groove Plugs, Accel 8.8 mm Wires, Hypertech Cap & Coil, Hypertech Chip, Hotchkis Strut Tower Brace, One Loud Stereo!
Old Sep 15, 2000 | 02:06 AM
Jza's Avatar
Jza
The unit itself? Or your radio or something?
You should get new 8mm spiral-core wires at the same time. My unit doesn't "buzz" that I've noticed, but when I hooked up the kill switch, it acted weirder than I would have liked so I left that option alone.
I mounted mine behind the driver-side headlight tucked between the cruise-control servo and the charcoal canister. Very, very nice location. Perfect distance from the battery *and* the coil so no wire lengthening or shortening was needed, it tucks in out of sight, and you can change the RPM pills right there (say putting in a 1500 limit if you have to leave your car at a shop to prevent joyrides). It also stays dry even in heavy rain.
I've also seen them on the pass. strut tower, on the firewall where the blower motor used to be (for those who removed their fan), under the plastic cover around the hood latch (in non-TPI Camaros). And one I saw was inside the dash where the computer is (lots of room down there on the passenger side, though I'd worry if the heater core ever took a crap)
Old Sep 15, 2000 | 04:25 PM
Tim Burgess's Avatar
Car: '92 Z28; Dk Teal; Her Pkg
Transmission: Richmond 6 Spd
Axle/Gears: Moser 9", Detroit Locker, 3.70
I haven't noticed any buzzing noise from the 6AL on my car. Here's how I mounted it:
Tim
Old Sep 26, 2000 | 02:39 PM
chris83z28's Avatar
My MSD 6AL makes sort of a fish tank sound but it only changes frequency with rpm. IT is loud enough to here if it is mounted inside but not if it is mounted under the hood. I have owned two and they both made a little bit of noise.
Old Sep 27, 2000 | 10:27 AM
'89Formula305TPI's Avatar
My MSD 6-AL makes absolutely no noise whatsoever..
Heres where I mouted it:
'89 Formula 305 TPI T-5
Check out my car HERE!
[This message has been edited by '89Formula305TPI (edited September 27, 2000).]
Fanatic1074
Oct 3, 2022 05:57 AM
Hotrodboba400
Dec 10, 2019 07:07 PM
RedLeader289
May 28, 2019 01:47 PM
meeklay812
Oct 1, 2015 03:46 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
