vents come on when accelerating, what the hell?
Old Sep 25, 2000 | 12:09 AM
mike88RS's Avatar
the dash vents next to the radio open when the car is hot and accelerating, sounds like a vacuum leak, but id prefer if someone had experieced it b4. i have my entire interior apart right no.w. the AC will turn on also if the selector is oncold. btw, 87 z tpi
Old Sep 25, 2000 | 03:31 PM
Tim Burgess's Avatar
Car: '92 Z28; Dk Teal; Her Pkg
Transmission: Richmond 6 Spd
Axle/Gears: Moser 9", Detroit Locker, 3.70
The check valve near the plenum may be defective - its vacuum source is a hose barb fitting at the passenger side rear of the plenum. It isolates the plenum vacuum source from the cruise reservoir, cruise servo, and the HVAC servo vacuum lines.
Tim
Old Sep 27, 2000 | 10:41 AM
'89Formula305TPI's Avatar
Check your vacuum reservoir canister, I believe that somone told me that HVAC system defaul position is vent (no vacuum at the manifold), so when you accelerate wide open throttle, there is a major vacuum drop at the manifold, therefore engaging you vents.
afterall HVAC are vacuum conrolled.
Just a suggestion
'89 Formula 305 TPI T-5
Check out my car HERE!
[This message has been edited by '89Formula305TPI (edited September 27, 2000).]
Pac J
May 17, 2020 10:44 AM
RedLeader289
May 28, 2019 01:47 PM
Fanatic1074
Oct 2, 2015 03:47 PM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
aaron7
Sep 30, 2015 09:15 AM
