Speedo not working
Old Sep 22, 2000 | 12:22 PM
james's Avatar
Speedo not working
I pulled the speedo from my 86' T/A and will be putting it into my 89' Bird. The speedo out of the T/A doesn't work. Is it more likely there is a problem other than the instrument cluster or shouyld I do something to it? Everything under the hood looks good?
Old Sep 22, 2000 | 08:08 PM
Tim Burgess's Avatar
Car: '92 Z28; Dk Teal; Her Pkg
Transmission: Richmond 6 Spd
Axle/Gears: Moser 9", Detroit Locker, 3.70
The speedo is cable driven & does not require power from the cluster. If you can see the speedo cable turning (after removing the cluster) when the car is moving, and the cable is long enough to engage with the speedo drive shaft, then the speedo itself has a problem. It can be removed from the cluster for repair.
Tim
Old Oct 3, 2000 | 09:56 PM
Tonyrodz's Avatar
Transmission: auto
My speedo in my 86 T/A has the elctric impulse type. Why the differance?
Old Oct 4, 2000 | 08:21 AM
Is the speedo digital, or a standard analog pointer type?
Jorlain
Aug 24, 2022 05:11 PM
Jeremys87
Jul 14, 2022 09:08 PM
Wade787b
Sep 29, 2015 01:15 PM
Irocohio
Aug 12, 2015 08:03 AM
beachrodder
Aug 7, 2015 04:27 PM
