RPM limiter
Old Oct 7, 2000 | 10:41 PM
bigdaddy's Avatar
RPM limiter
Is there any way to disable rpm limiters, or is there a chip to install to get more rev? 1987gta5.7
Old Oct 9, 2000 | 08:02 AM
Tim Burgess's Avatar
Car: '92 Z28; Dk Teal; Her Pkg
Transmission: Richmond 6 Spd
Axle/Gears: Moser 9", Detroit Locker, 3.70
Do you mean the speed limiter? If so, that function is set in the PROM & must be changed there - it cuts the fuel supply until a lower speed is reached (it has some hysteresis) or, as a temporary work around, you may try disconnecting the VSS wire to the ECM - I wouldn't use that as a permanent mod, though.
Tim
RedLeader289
Sep 23, 2015 06:50 AM
wisemanz28
Sep 20, 2015 01:26 PM
Stroopwafel
Sep 11, 2015 06:38 AM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
