how to activate daytime running lights
Old May 21, 2002 | 12:28 PM
uk89camaro's Avatar
My '89 RS 305 was imported from California in '96 (not before some sh*t clocked it back 50k miles! I might add), and I believe I have DRL, see pic. How are these activated in normal circumstances? One assumes I could easily patch in from the side lights to run them on dip?
Regards
Attached Thumbnails how to activate daytime running lights-camarofeb02fos1.jpg
Old May 27, 2002 | 12:31 PM
uk89camaro's Avatar
somebody must know how these things are supposed to work.
Any help appreciated.
Old May 27, 2002 | 12:42 PM
ahesje's Avatar
I live in Canada where all cars manufactured since Nov/89 are required to have DRL's. I also lived in the US recently and went through the process of importing three vehicles to Canada when we moved back. Your post raises a couple of issues;
Firstly, IMHO no US soldcars the age of yours had DRL installed from the factory.
Secondly, most cars with DRL's actually have a different wiring harness that will accept the DRL switch and the module that reduces the intensity of the lights while DRL's are on. We have a US bought 1995 Mark VIII that still doesn't have DRL's, although it is required to, because the wiring harness simply doesn't accomodate the DRL swith etc.
In case your real question was simply how do they work, in Canada your headlights only (no park lights) come on when the car is started and being driven. Some vehicles are wired so that the DRL's are on all the time the ignition key is on and some are wired so that the DRL's only come on when the parking brake is release, or it is taken out of Park etc.
Hope this helps.
Old May 27, 2002 | 01:04 PM
uk89camaro's Avatar
If I read you correctly the DRL's were just side lights operating all the time. Have a look at the picture below, I thought the lamps in the front clip were the DRL's, or are they front fogs. (There are no switches in the car to operate these lights.)
Old May 27, 2002 | 03:02 PM
86IROCZ's Avatar
Those are your front turn signals
Old May 27, 2002 | 03:25 PM
uk89camaro's Avatar
never checked from the outside. Am I dumb or what! No..don't answer that....I can't believe that....doh!...dumb@ss...mother...etc...etc..
Please delete this post immediately!
Old May 27, 2002 | 08:06 PM
JohnnyIROC-Z's Avatar
Car: 1991 T-Top RS
Engine: 305 TBI
uhh hehe and they're also your running lights. pull the headlight switch out one click those come on. then turn on the blinker and they get brighter.
Old May 27, 2002 | 11:15 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
how to activate daytime running lights :
Turn your lights on when you get in the car!!
:lala:
Old May 28, 2002 | 12:09 AM
uk89camaro's Avatar
You can torture me as much as you wish eb. I'm off to play golf with a customer today, so I don't care....
Old May 28, 2002 | 01:53 AM
ebmiller88's Avatar
J/K...
Old May 28, 2002 | 10:30 PM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
Engine: 350, ZZ4 equivalent
Transmission: Pro-Built Road Race 700R4
Axle/Gears: 3.23 Dana 44
You could easily rig up a relay to turn on your parking lights when you start your car. Your parking lights light up the front to turn signals.
Old May 29, 2002 | 12:55 AM
uk89camaro's Avatar
IROC Z,
What sort of relay, and how? I not great on auto-electrics (did manage to hardwire a fan switch with a separate LED last weekend though ).
p.s. How do you insert a graphic under your user name in the posts?
Thanks.
Old May 30, 2002 | 08:27 PM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
I made this real fast, it should help
Old May 30, 2002 | 09:37 PM
ebmiller88's Avatar
Cool!!
Old May 31, 2002 | 02:52 AM
uk89camaro's Avatar
IROC Z,
I think even I can manage it now. Thanks.:hail:
OLDYELLR
Car Audio
Sep 30, 2015 07:10 PM
Jae992
Aug 27, 2015 09:07 AM
justin57
Aug 20, 2015 07:05 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
Omega
Aug 10, 2015 12:46 PM
