Hatch pulldown motor
Old May 22, 2002 | 06:11 PM
T/Aguy's Avatar
hey if anyone can help me out i would really appreciate it
i have an 86 trans am 5spd carbd
my hatch motor is stuck in the down position and will not close the hatch however the latch itself still opens with the button the motor is just stuck down
Help please
Old May 23, 2002 | 12:48 AM
StngKlr's Avatar
Car: 89 RS
Transmission: TH350
Welcome Aboard.
I'm almost positive that your Nylon Gears inside the motor are shot. I have had similar happen to me. Pull out the motor and inspect the gears inside, more than likely you need to replace these, or get a whole new rear hatch motor assembly.
Kinda sux when you are a newbie with a question, but almost everyone in this Forum will help you out. Let us know.
Old May 23, 2002 | 05:23 PM
92blue's Avatar
Former Sponsor
Car: 1992 Camaro RS
Engine: Yet another 350 TPI
Transmission: Borg Warner 6 spd
I think StngKlr is right. That sounds like the gear that hooks up to the pulldown motor. Go remove the plastic panel that goes over the hatch pulldown assembly, and remove the motor from the assembly. You should see a whitish gear that engages the motor. Take a real good look at it, and make sure it doesn't have any stripped teeth. If it does, its an easy fix. I think the gear is like $5 from GM.
Old May 23, 2002 | 06:47 PM
jstarsart's Avatar
If the circuit is bad then it also will not latch. I fixed that on mine by turning the little button thing (sorry I don't know what its actually called) on the lower right side (as you face it from the inside). Apparently it lets you close it manually, so you have to close it kinda hard too. I'm still very new too so I'm not sure if that has anything to do with your problem.
zayne0
Aug 24, 2015 07:22 PM
neekolzun
Aug 24, 2015 04:59 PM
madsv1000
Aug 20, 2015 06:45 AM
stalkier
Aug 13, 2015 12:59 PM
1nastygta
Aug 8, 2015 07:38 PM
