Help
Old Oct 17, 2000 | 04:48 PM
Zeplin1073's Avatar
Help
I have a 91 RS. It has a 305 V8 auto and I need a new tach gauge. Mine took a crap on me and evryone I have talked to will only sell the ENTIRE cluster. I just want the piece for the tach only,I have my old one out so someone must sell each part. Help!
Old Oct 17, 2000 | 10:12 PM
87 Firebird's Avatar
From what I've seen when I've had my guage cluster out, it's all one big unit. Granted, anyone with enough determination can put just a tach into it, but why not just check for loose wires/bad connections? Also, it helps if you describe your problem in your subject line. People often overlook nondescript posts.
Old Oct 18, 2000 | 08:48 AM
Tim Burgess's Avatar
Car: '92 Z28; Dk Teal; Her Pkg
Transmission: Richmond 6 Spd
Axle/Gears: Moser 9", Detroit Locker, 3.70
You will probably not find a junk yard that will break up a cluster. A cluster should run around $75 to $100 from a junk yard. Try posting a wanted ad in the classifieds, and do a search on "cluster", "tach", etc. in the parts for sale section.
Tim
