Cooling Toggle?
Old May 23, 2002 | 12:12 PM
FatOne's Avatar
Cooling Toggle?
Yes I've read most of the old post. Nothing to my likeing so I'll ask a different one. Have one fan, in 85 Z28 350 Carb. setup. "ALL OF THE ECM AND THE WIRING IS OUT OF THE CAR" Simple right? Well my brain can't think anymore. Have power wire for fan, then the ground. Want to hook up seperate fuse inside engine bay. Then run hot wire to toggle switch. I don't want to have to run a direct to the battery. Can I use one of the Fuse panel Ignition spot. You know so when the key is turned toggle is hot. When I want to turn it on I can. I don't want to run all of the time. Also like I said that I need it to go into a fuse port. Anyone with some ideas?? Or a crude drawing of something to go off of.
Linson
Oct 24, 2025 02:00 PM
sheachopper
Jul 31, 2019 11:27 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
ndndndnd
Sep 28, 2015 08:00 AM
327IROC85
Sep 23, 2015 12:11 AM
