Intermittent code 33 & 34 HELP!!!!
Old May 23, 2002 | 09:14 PM
quiksilver1j's Avatar
I have this prob every so often ( at least once a week) i will be drivin my car and all of the sudden i will loose power and the check engine light will come on and it will idle fine but if you rev. it nothin just bogges down, also if you take it out of gear and rev. it its fine....and if you turn the car off for like 30 sec and start back up its fine. i checked the codes its 33 and 34 what do i do????
87 305 FI
thx john
Old May 23, 2002 | 09:18 PM
do i just need a tune up could the knock sensor be causin the problem cause i need new plugs and wires really bad !!! could that be it?
Old May 29, 2002 | 03:57 PM
406IROC-Z's Avatar
code 33 and 34
Just so you know code 33 and 34 are for the MAF sensor. Code 33 is for a high voltage reading and 34 is for a low voltage reading. I would first change your power relay and your burn-off relay, they are the cheapest to buy, about $20 bucks canadian so pennies in the states. Then try changing your oxygen sensor and then lastly your 300 dollar MAF sensor.
Hopefully this helps
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
Reid Fleming
Oct 10, 2015 09:56 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
