My power locks are possed
Old Oct 18, 2000 | 06:25 PM
Aaron91RS's Avatar
Car: RS
Axle/Gears: 9" for the ladies
I drive down the road and they keep locking and unlocking. I turn the car off and lock the doors and the stupid things unlock themselves!! The only thing I can figure is I had to clean the Master cylinder with water the other day and probably got water on some wires or relay. Is there a relay for the pwer locks around the master cylinder and if so what color wires run in to it.
I checked the fuse but it is ok, what else could it be?
Old Oct 19, 2000 | 08:31 AM
steve88iroc's Avatar
Car: 1988 IROC-Z
Transmission: WC T5
I had this same problem, and overnight it actually drained my battery. It turned out that I had tightened the armrest on the door too much and this was causing the problem. I loosened the armrest and presto, no more problem with the locks. Hope this helps.
Old Oct 19, 2000 | 08:57 AM
Tim Burgess's Avatar
Car: '92 Z28; Dk Teal; Her Pkg
Transmission: Richmond 6 Spd
Axle/Gears: Moser 9", Detroit Locker, 3.70
If the switches in the doors get wet, the contacts will corrode due to electrolosys & conduct enough current to operate the relay coils. Pull the switches apart & clean them with contact cleaner if the contacts are corroded.
Tim
Old Oct 20, 2000 | 12:24 AM
theformula's Avatar
I was an idiot and sprayed armor all near them one day. They were possessed for about a week. Freaked out my girl. haha
You don't have to clean anything if you don't want to..the problem will eventually disappear. Trust me.
'92 Formula
305 TPI
Mods: SLP catback,SLP air foil,ported plenum,Crane AFPR (49psi),MSD6AL,homemade cold air,K&Ns,3:73s,JET fan switch...SLP 1 5/8ths are coming...oh yes
Old Oct 20, 2000 | 09:01 AM
If the contacts have been coroded with water, over a period of time, the current flow and corrosion will increase over time.
Tim
Old Oct 20, 2000 | 09:45 AM
theformula's Avatar
oh. hehe.
Old Oct 26, 2000 | 04:34 PM
Josh 91RS's Avatar
i have a 91 RS that i just purchased recently and sometimes when i start up my car a few seconds later it automatically locks. I have yet to find any consistency in when it does this, and am afraid one day i will go to warm up my car and lock myself out. Anybody have any clues as to why it does this, or if its normal when it is triggered?
BRoss99
Aug 10, 2025 05:08 PM
IrocBuzz
Camaros Wanted
Nov 20, 2015 11:29 AM
mantaguy
Sep 1, 2015 08:39 PM
sailtexas186548
Aug 24, 2015 10:11 PM
zayne0
Aug 24, 2015 07:22 PM
