Power door locks not working
Old Oct 30, 2000 | 05:19 AM
89FirebirdUK's Avatar
Hi
I'm having some problems with my power door locks. I have a clifford alarm which controls the locks, so when I switch on the ignition the doors lock and switch off the doors unlock.
Currently when I switch on the ignition the power door locks don't lock, although they do clunk as if they were going to lock the doors.
Also using the buttons to control the door locks, the lock button doesn't lock either.
So, is this a problem with the alarm system or some other electrical problem ?
Can I use the keys to override the power door locks ?
What's the best way to diagnose this problem.
Geoff
Old Oct 30, 2000 | 11:57 PM
Justins86bird's Avatar
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
This is a common problem. Take off your door panels and hose the door lock solenoids and linkages with WD40 and work the lock manually a few times. Then try to use the power lock button. Keep working the locks and lubing them down to they work good.
-Justin-
T-Top '86 5.0L LG4 700R4 WS6 Now Bilstein equipped!
T-Top '92 5.0L TBI 700R4
My '86 Firebird Homepage
The F-body Model Kit Pictoral Archive (updated 9/18/00)
There can be only one!!
Old Oct 31, 2000 | 03:07 AM
Hi Justins86bird
So does the key use a separate mechanism to lock the doors ?
Geoff
Old Oct 31, 2000 | 06:57 AM
Just a follow up, I can use the keys to lock and uplock the doors and they work fine.
Using the power locks, the unlock button, does indeed unlock the doors, but using the lock button it fails to lock using either the driver or passenger lock buttons.
Can some body explain how the powerlocks work ?
Old Oct 31, 2000 | 07:52 PM
Tim Burgess's Avatar
Car: '92 Z28; Dk Teal; Her Pkg
Transmission: Richmond 6 Spd
Axle/Gears: Moser 9", Detroit Locker, 3.70
If they make the "clunking" noise when the buttons are pressed, then the mechanisms need lube, as Justin said, above. The electromagnets are not strong enough to move the lever if the mechanism gets gunked up.
Tim
BRoss99
Aug 10, 2025 05:08 PM
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
colton_carlson
Mar 8, 2019 12:21 PM
