should i put a inline fuse on my fan switch in my car?
Old Oct 31, 2000 | 04:35 PM
hookin88formula's Avatar
i was wondering i just hard wired my fans and put a switch on the inside of my car. i have the power wire that goes from the fans to the switch and then since the switch lights up when its on i have a wire going to the fuse block. should i put a inline fuse on the wire going to the fuse block? i am having problems blowing fueses in the fuse block will this help?
1988 firebird ws6 formula350tpi msd 6al box blaster 3 coil accel 8.8 race wires hooker shorty headers hooker cat back system pro shift light a pillar gauge pod and water temp and air/fuel ratio gauges autometer oil pressure gauge b&m mega console shifter, march underdrive pullies, tpis airfoil cvr high torque starter (love it)
best 1/4 mile run of 14.44@ 96.53
this run is before the new exhaust system
Old Oct 31, 2000 | 08:29 PM
Duffster's Avatar
Car: 2001 Camaro Z28/1995 Camaro Z28
Engine: just a little 5.7(LS1-320/340 RW)
Transmission: SMOOOOOOTH T-56/Auto. . .
Axle/Gears: 3.42 and 2.73
i would recommend using a relay for powering the fan so as to minimize the amperage/wire you're running around the car...and yes...get a fuse for the relay
BRoss99
Aug 10, 2025 05:08 PM
Ghettobird52
Jul 5, 2024 11:18 PM
RazorN8
Jan 7, 2022 11:44 AM
Fronzizzle
Aug 9, 2015 01:15 PM
Leggman1
Aug 6, 2015 04:15 AM
