A neat idea, need help...
Old Nov 4, 2000 | 01:06 PM
Mark305TBI's Avatar
Car: '00 Chevrolet Corvette
First, go check this out...
Road Dyno
Now, my idea was that you could use this to plot your estimated power output and rig something up to record the O2 and MAP sensor readings coming into the ECU. How would you rig a recorder up to record voltage over a period of time (like 10-20 seconds)? I thought that it would be a real kick-*** tuning tool. BTW, can't do it ALDL, the baud rate is so slow it only updates once ever couple of seconds...not near quick enough. I was thinking that 100 datapoints on a 10 second run would be about right.
-Mark W.
'88 SC Camaro w/ 305 TBI
Old Nov 6, 2000 | 01:40 PM
Tim Burgess's Avatar
Car: '92 Z28; Dk Teal; Her Pkg
Transmission: Richmond 6 Spd
Axle/Gears: Moser 9", Detroit Locker, 3.70
Sounds kind of like an AutoXray. It captures data at a 1 second rate & outputs it in a display readout form. A Diacom is PC based & will dump data to a file. The older ECMs had a slower baud rate, relative to the newer ECMs.
Tim
gta892000
Aug 11, 2019 11:16 AM
Zane Story
Oct 8, 2015 12:40 PM
Nick McCardle
Sep 10, 2015 08:36 PM
Djmathis123
Sep 8, 2015 08:42 PM
