no matter what it wont start without the starter switch
Old Nov 12, 2000 | 05:24 PM
MARK28V6's Avatar
the car will not start no matter what if the starter switch isnt used im sayin if i push the clutch all the way in then nothing happens by the way the security light comes on when i turn on the ignition and then goes off the check engine light stays on till teh motor starts thanx i appreciate the help do you think its the clutch switch
Old Nov 12, 2000 | 05:46 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
First of all, you don't need to keep posting new topics, just reply to the ones you already started.
Second, the clutch switch may be bad, since you have to let off the clutch some before it will start, but it IS NOT the source of your problem since you still need the switch under the dash. It would be in your best interest to at least find a wiring diagarm.
When you crank the car, power goes from the Ignition switch, to the clutch start switch, through the Theft deterent start inhibit relay, and to the starter. You will need to trace down, starting at the Ignition switch where power drops off.
If you live in Southeastern US, check us out!
South East Thirdgen
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey,
22# injectors,
Ported Plenum,
TB Coolant Bypass,
SSM SFC,
Boxed LCAs,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims.
'97 Bonneville SSE
Old Nov 12, 2000 | 05:52 PM
MARK28V6's Avatar
sorry as im new to this but i appreciate the help ill try it and keep ya poseted
BRoss99
Aug 10, 2025 05:08 PM
Caspar
Jun 19, 2016 11:19 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
92camaroJoe
Aug 13, 2015 06:07 AM
86Base
Aug 8, 2015 01:34 PM
