ecm questions
Old Nov 14, 2000 | 06:22 AM
ausrs's Avatar
ecm questions
ok am going to change my 1991 tbi to 1986 tpi
to avoid any silly speedo probs would it be possible to use the tbi ecm to run the vats and accessories and piggyback the 1986 ecm to run the engine (tpi etc)
Old Nov 14, 2000 | 12:31 PM
Tim Burgess's Avatar
Car: '92 Z28; Dk Teal; Her Pkg
Transmission: Richmond 6 Spd
Axle/Gears: Moser 9", Detroit Locker, 3.70
The '86 ECM does not require a VATS enable input, but keep the VATS module connected to the harness, as it will continue to control the starter enable relay. The VIN E TBI setup uses a speed buffer module that is external to the ECM, so the output of the speed buffer module may be connected directly to the '86 ECM. The TBI ECM may be removed, completely.
Tim
ezobens
Aug 19, 2015 10:29 PM
355tpipickup
Aug 19, 2015 10:02 PM
redmaroz
Aug 16, 2015 11:40 PM
djmarch
Aug 10, 2015 08:42 AM
