Console Panel Won't Come Off !
Old Nov 16, 2000 | 03:41 PM
GTA88's Avatar
I've been posting about a cig lighter I want to disconnect in the center console panel of my 88 GTA. I got the 3 screws out easily enough. And I got the rear part of the console loose, but the front part is stuck under the radio and even if I push the radio in (doesn't really move much anyway) and pry on the console it won't come up ! I moved the gearshift into neutral so it isn't blocking anything. What am I doing wrong ? What's the trick ? I don't want to break anything. The console panel is thin plastic, and pretty old and creaky, seems like it would snap in half with some force applied to it !
Old Nov 16, 2000 | 10:59 PM
junkyarddog's Avatar
Car: 1999 Chevy Cavalier
Engine: 2.2
Transmission: 5 speed
Axle/Gears: it's part of the transmission
did you get rid of the "lip" above the radio?
I have an '84 so it might be a little different,if yours has it,there's two 9/32" hex screws on the bottom. don't be afraid to put a little stress on the plastic console it'll give more than you think.do it in good light it's a challenging piece indeed.
Old Nov 17, 2000 | 10:26 AM
GTA88's Avatar
Junkyard Dog,
I just got done using the "stare at it some more" method.
I went looking at my radio for the hex head screws. Didn't find them BUT... as I tweaked the 'lip' surrounding the radio it gave way and came right off !! It is held on by a couple friction points. The console was really sticking on this 'lip', as you suggested. With the lip off, the console should now have room to come out. Thanks for the inspiration. Now on to glorious victory over the cig lighter....
GTA88
Old Nov 18, 2000 | 02:29 AM
Engine: 2.2
dismantling thirdgens is always a fun adventure.
Hotrodboba400
Dec 10, 2019 07:07 PM
88HARDTOPIROCZ
Sep 18, 2015 10:30 PM
Fronzizzle
Sep 8, 2015 12:10 PM
Third_Gens_Rule
Sep 3, 2015 06:56 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
