Attn: John Millican
Old Nov 21, 2000 | 12:06 AM
Tad's Avatar
Tad
Attn: John Millican
? about the gray plug. I understand where the pink w/black stripe goes but where does the lt/blue and the lt/green wires feed to and the tan w/white strip turns to brown and there is two in the same pin what do they go to? thanks for any Help.
Old Nov 21, 2000 | 01:00 PM
Tim Burgess's Avatar
Car: '92 Z28; Dk Teal; Her Pkg
Transmission: Richmond 6 Spd
Axle/Gears: Moser 9", Detroit Locker, 3.70
Which gray plug? Where is it located & what does it connect to? What type of F body & year & engine & trans?
Tim
Old Nov 21, 2000 | 07:19 PM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
He's talking about the C221 connector next to the ECM on a 1986 TPI. It feeds the INJ 1 and INJ 2 power from fuses to the ECM, it is gray in color.
The tan/wht feeds to the coolant fan relay from the "FP-FAN" fuse.
The other colors you are asking about I don't understand. Are you looking at my carb to TPI wire drawing?
86 Camaro Sport
383 Speed-O-Motive Crate Engine, Trick Flow Heads, 58mm Accel TB, 3.73 Auburn Pro, SLP Cold Air Induction and Headers, Dynomax Cat-back, Serpentine belt setup, Dual IROC Fans.
http://www.sethirdgen.org/octride.htm
Old Nov 22, 2000 | 01:23 AM
Tad's Avatar
Tad
The other two wires(lt/blue, lt/green) are for cars with manaul trans. I found that out after I spent some time studing the wiring diagram. My next question is the wiring harness I have came out of 87 trans am with 305 tpi and manual trans will this even work with 350 tpi(ZZ3) and TH700r4?
okfoz
Oct 13, 2015 02:19 PM
okfoz
Sep 17, 2015 10:30 AM
okfoz
Sep 15, 2015 05:22 PM
jtwoods4
Sep 3, 2015 05:39 PM
