After market ignition boxes.................
Does an aftermarket ignition box such as the MSD 6AL or the Accel 300+ digital ignition replace the ESC module? I am swapping my TPI 305 for a shiney new 383! just don't want to go and by the 350 ESC and Knock sensor when the aftermarket part does the job. Any help is appreciated. Thanks.
1989 GTA TRANS AM
305 TPI, 5 SPD
SWAPPING TO TPI 350 NEXT MONTH.
1989 GTA TRANS AM
305 TPI, 5 SPD
Car: 1992 Camaro RS
Engine: 5.7
Speaking of the ESC what does that do? My car seem to run fine with it or without it????
92 RS
350
Street & Performance MPFI
TFS heads
Crane Rollers
MSD Digital 6 Plus
24lb injectors
ZZ3 cam
Edelbrock Headers 1 5/8
3" Exhaust
Hi Flow 3" Cat
stock T-5
stock rear 3.08
koni yellow adjustable front
twin turbo glass hood
T-tops
Auto Meter Ultra Lite Series 2 5/8 gauges
Color: Teal Green
92 RS
350
TFS heads
Crane Rollers
MSD Digital 6 Plus
24lb injectors
ZZ3 cam
3" Exhaust
Hi Flow 3" Cat
stock T-5
stock rear 3.08
T-tops
Color: Teal Green
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
The ESC module processes the signal from the knock sensor. If you're not getting any knock, it's not doing anything.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
1991 Camaro Z28
13.25 @ 107.18 MPH
Southern California
RedLeader289
May 28, 2019 01:47 PM
Gunner242
Dec 25, 2015 04:49 PM
