MSD 6A ignition
Old Nov 28, 2000 | 07:59 PM
chicksL69's Avatar
MSD 6A ignition
Hi, I have an 84 Camaro with a brand new(rebuilt completely at a machine shop) 350. The stats are on my signature, anyways I have a stock HEI and ignition, I am looking into buying the MSA 6A ignition pack that comes w/ a MSD 6A ignition and a Blaster 2 coil for my HEI. The part number is MSD-8400 in the summit catalog. So is it a good upgrade? I'm not too hot on the idea of running a 350+ hp engine w/ a stock ignition, any suggestions good or bad I would appreciate, thank you!
84 Z28 HO
62-67 327 block
new 350 crank
.040 overbore
461 double hump heads
2.02/1.60 valves
edelbrock perf RPM intake
edelbrock 600 cfm carb
th-350 tranny
B&M stage 2 Transpak
aluminum roller rockers
489 lift cam
7 quart oil pan
Keith Black pistons
screw in studs/guideplate
Old Nov 30, 2000 | 02:33 PM
chicksL69's Avatar
Can someone please help me? I really need to know this, thank you!
Old Nov 30, 2000 | 03:15 PM
Jeremy_84_F41's Avatar
Car: 1991 Formula L98
Axle/Gears: 3.73:1
Yes it is a good upgrade. I have heard there is a very noticeable difference with this box...
Hotrodboba400
Dec 10, 2019 07:07 PM
RedLeader289
May 28, 2019 01:47 PM
RedLeader289
Sep 23, 2015 06:50 AM
TexasMaro
Sep 15, 2015 06:50 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
