throttle kicker
Old Nov 30, 2000 | 04:28 PM
spitfire350's Avatar
throttle kicker
is the throttle kicker the cylinder right in front of the throttle linkage? If thats what it is, I gotta qestion, mine wont let me adjust the idle speed below 1200rpm because it is pressing on the linkage and the ac isnt even on. Can i just unhook the wire to it and adjust the screw or will unhooking it hurt the car? thanx for the info.
later
keep the stang's far behind u and the cops even farther
Old Nov 30, 2000 | 05:13 PM
Blade's Avatar
Well unhooking that "solenoid" wont hurt anything. It's also adjustable if you look at it. Screw that little nut in and it should go in far enough so you can adjust your idle.
92 Z28 L98 350
Ported and polished heads, ported stock TPI base, ported plenum, Comp Cams XR270HR-10 cam (lift .495/.502 duration 218/224 lobe separation 110), Edelbrock TES headers, LT4 valve springs, Crane AFPR, Flowmaster catback with LT1 style tips, MSD coil & wires.
Best ET 13.5@105 mph
"Take that auto, drop it in first, hold the brakes, stomp the gas and grin from ear to ear! :-)
http://www.truspeed.org/Members/Chev...dmondIndre.htm
Linson
Oct 24, 2025 02:00 PM
Pac J
May 17, 2020 10:44 AM
Z28/ZR1
Oct 23, 2015 01:04 PM
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
Giocio
Oct 1, 2015 12:20 PM
