Electric Speedo innacuracy
Old Jun 2, 2002 | 11:24 PM
phineas's Avatar
Can anyone think of a reason why the electric speedo in my '91 RS seems to lose it's accuracy at speeds of ~70mph+ ? It seems to read much faster than I'm actually going, by about 10-15%. My tires are the correct size, and I have no reason to suspect the gearing on the VSS is incorrect. Is it possible there's some sort of electrical wierdness going on ?
Kyle
Old Jun 3, 2002 | 08:34 AM
92RSB4C's Avatar
The same thing is happening to me. I don't know why.
Old Aug 25, 2002 | 01:35 PM
sanchez's Avatar
Car: 1990 Iroc-z G92
Transmission: 5 Speed
my 90 IROC has been having that problem also and it is bone stock if anyone knows please help
Old Aug 25, 2002 | 01:42 PM
Ryan_Alswede's Avatar
Car: 1992 Camaro RS & 1992 Camaro RS
Engine: 3.1 L v6 & 305 (5.0L) v8
Transmission: 4L60 Auto
Probley a worn plastic speedo gear on the magnetic pick up on the tranny or the sensor itself is bad. HOW do you all know it's off?? Mine is perfect and I have 88,000 right now. The sensor with out the gear is $50 bucks if you just want to replace it.
Old Aug 25, 2002 | 01:55 PM
sanchez's Avatar
any time I see those signs that tell you your speed i check at various speeds when my car is saying 30 im going 26 at when i think im going 50 it says 42 and gets worse at higher speeds . Now i Know those stupid signs are good for somthing.
Old Aug 25, 2002 | 02:00 PM
Be careful with those signs, they aren't as accurate as a rador gun pointed RIGHT at you. I would say your speedo is fine just that the sign isn't directed at you correctly.
SRKLEGIN
Oct 29, 2015 06:38 PM
TMZIrocZ350
Oct 7, 2015 12:09 PM
rs_z28_vert
Sep 30, 2015 09:47 PM
lanceflame44
Sep 25, 2015 12:28 PM
TrevinE
Sep 14, 2015 03:20 PM
