Need help quick! Knock sensor question!
Old Nov 13, 2000 | 02:18 PM
Rock90rs's Avatar
Car: 92 RS/90' vette
Engine: Heads/cam/miniram/blah blah blah..
Transmission: T5/700!
Axle/Gears: 3.08
I busted the end of it off during my header install. Right now it is obviously not hooked up. Ive known a few TPI guys that leave theirs disconnected because of their gear drives. I know when it sences a knock it grounds to the ECM. If its not connected, then it cannot ground, right? A mechanic told me that leaving it disconnected will cause it to throw a code, retard the timing and run lean. (with possibility of burning a piston.) So far it has run no code, and the guy i know with the gear drive has left his unplugged for some time with no problems.
What should i do? go run out there now and change it? or can it wait untill I have the time to do it?
90 RS
305
700r4
www.lg4performanceteam.org
Old Nov 14, 2000 | 08:55 AM
Tim Burgess's Avatar
Car: '92 Z28; Dk Teal; Her Pkg
Transmission: Richmond 6 Spd
Axle/Gears: Moser 9", Detroit Locker, 3.70
You should replace it, but leaving it disconnected for a while should not hurt the motor - unless you hear excessive pinging, that is.
Tim
Old Nov 22, 2000 | 02:11 PM
Nitro Don's Avatar
When I disconected the knock sensor on my
90 TA it threw a code and ran like crap.
So, I mounted an other knock sensor under the dash,grounded it and wired a on/off/on toggle switch spliced in between the the real knock sensor wire going to the ECM.
Now when I want to run without the sensor I hit the switch over to the dummy sensor and the ECM still thinks its reading the sensor thats in the engine.
Hope this helps,
Don
1990 Trans Am WS6
305TPI 700R4
ENGINE:
150hp NOS kit
March underdrive pulleys
Edelbrock headers(JetHot)
Mac off-road pipe
Flowmaster exaust
Jacobs ultra coil
K&N filter
Fulley ported base,
runners,& plenum
Crane AFPR
Hypertech airfoil
Crane 1.6 rockers
210/220 .533/.544 Cam
W/P Torquer heads
Edelbrock TPI Base
Edelbrock TI Runners
Edelbrock 52mm T.B.
TRANSMISSION:
Richmond 3.73's
Auburn posi
B&M Mega shifter
B&M Transpak
Vette servo
FUTURE MODS:
W/P Torquer heads
Edelbrock Base
Edelbrock Runners
Edelbrock 52mm TB
BEST RUN:
12.48 @ 109.23 MPH
Old Nov 22, 2000 | 02:22 PM
Another way to do the bypass is to measure the resistance of your knock sensor & use a resistor close to that value in place of the sensor. I did this for a while after installing my gear drive to verify that it was not causing the ECM to think detonation was occuring - turns out the gear drive does not cause a problem with the knock retard system. The resistor prevents the ECM from setting a code by simulating the currrent flow that would normally occur with the sensor in place.
Tim
Old Nov 30, 2000 | 05:26 PM
Blade's Avatar
The resitor is exactyl 3900 ohms
Old Dec 1, 2000 | 04:57 PM
The resistance actually varies, depending on the year & engine VIN number, so it's best to measure the sensor in your setup, to be sure of its resistance value.
Tim
bamaboy0323
Sep 3, 2015 06:07 AM
db057
Aug 22, 2015 08:17 PM
redmaroz
Aug 16, 2015 11:40 PM
happyhapka
Aug 15, 2015 04:42 PM
